I got my Liquidator installed as most with an above ground pool I had to close the suction valve a bit to get the flow rate up through the Liquidator. I also added a needle valve which I dont know it it is going to work for me because now I can not max out the flow meater. it seams to be keeping my fc at 6 ppm so I am going to turn it down a bit now. What do you think of the install ok or do I need to change anything?
