Hello All,
This is my first post on this forum. I have been reading and watching for a couple of weeks so far and have learned a tremendous amount. Thank you all so much for this forum and the time you spend updating it. It is awesome!
Now... on to my predicament. In short, my pool (26k gallon inground vinyl) turned into a moat over the winter. The motor on my pump went out so I closed it without covering it. Needless to say, algae was a huge problem. After listening to the local pool store and spending waaayyyy too much money, I have started my own remedy.
My pool is now clear for the most part, but my numbers are still off. I still cannot see the bottom in the deep end either. Can anyone tell me what I should do next? I use a Taylor 2006 test kit. I have also just started using the BBB method and have already used 4 4lb boxes of Borax and over a gallon of Ultra 6% bleach. Any help would be great! Thanks ahead of time.
FC = .6
CC = .6
PH = 7.0
TA = 70
CH = 140
CYA = 140
FC = .6
CC = .6
PH = 7.0
TA = 70
CH = 140
CYA = 140
