Results 1 to 7 of 7
Thread: DIY Solar Heater
    Jan 2008
    Malaysia
    109
    DIY Solar Heater
    I am thinking of building my own solar heater using copper tubing as we do not have the type of DIY solar heater kits that is available on your market. Can anybody advice on the following?
    1) what are the consequences of 4000 - 4500 ppm salt against the copper tubing?
    2) anybody knows of any links to any website on the design and construction of such heater?
    I intend to install the panel and tank on top of the roof and have my pump do the circulation between heater tank and pool water. Any suggestions willbe most appreciated.
    Thanks.
    8,000 gal IG concrete & tiled lap pool, 1/2 hp pump, 24" sand filter, SWG Auto Clean, whole pool under shed, 3 X 2ft waterfall one end overflow the other end. TF100 Testkit. 80 F Water whole year round.
    Mar 2007
    Morris, IL
    477
    You should scrap the copper and buy a solar panel. Copper is almost $3 a pound isn't it?
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Jul 2007
    Alamo, CA
    187
    Rather than copper, I'd use some black plastic tubing that is stabilized against UV damage. Copper is probably better when trying to get really hot water (>110 degrees, for example), but the plastic is cheaper so you can better afford to create more surface area with it.
    Panels from companies like FAFCO aren't very expensive, so it's worth looking into the commercially available options to compare costs against any homemade ideas.
    blubluenoiseise
    My pool: 14,750 gallons in-ground plaster
    FAFCO Solar panels (seven 4' x 12') with a Goldline automatic controller
    1/2 HP WhisperFlo filter pump, Kreepy Krauly cleaner, Cartridge Filter
    Aquarite SWG, Satisfied user of the TF-100 Test Kit
    Jan 2008
    Malaysia
    109
    Thanks guys for the respond.
    Solar panel, I have to import from USA or nearest would be Australia. The only UV staiblized plastic would be poly pipe which is quite thick (high pressure). How would such plastic withstand temp in excess of 95 F whole year round in term of UV protection? My current water temp is 80F only (under shed) and I only intend to raise the temp another 5-6 F.
    FYI, copper pipes prices ranges from a USD a ft for 3/8".
    Thanks.
    Mar 2007
    Morris, IL
    477
    3/8" is not going to get you any type of flow and will not make a difference. You would need probably 1" or larger at least something black, polyethylene preferably I would imagine.
    steve
    Jun 2007
    S.Tx
    14
    18' Intex Ultra Frame, Hayward Power Flo Matrix 2 Speed 1 HP pump, Hayward Star Clear C-500 w/81 SqFt cart.
    Jan 2008
    Malaysia
    109
    Thanks alot. I appreciated it.
