Well I got new equipment and decided to get my pool back running got a ta60 d with a dual speed superflo pump and intermatic box. I have a two valve setup without anything else installed problem is I turn the pump on and get strong suction at first when vacuuming then it peters out to nothing .while I'm running I will get huge air bubbles coming out of the return jets all the plumbing above ground is new and I cant find any leaks there or around the pump or the filter so I'm wondering if I should just start digging up lines we had problems with Palm tree roots once before thats all I can think of to do ?? heres my setup i can get more pics if needed
