- May 25, 2011
- 31
water is fairly clear, just not crystal. again i looked at the chlorine/cya chart Isaac suggested, with a cya of 60 my shock target is 24, correct? if so, that increases my chlorine volume to 11 gallons. should i go thru the whole draining process again? UGH!! or add the 11 gals of chlorox?? i am checking the FC CC and TC using the chlorine drop test (R870 powder, swirling adding R871 solution, counting drops...etc) is this the same as the FAS/DPT, also mentioned by Isaac? this will be TRULY the 7th time to drain...not just a little drain. maybe I should call someone to come on site before i really mess up the liner...OR what the hay....its just a liner...right? close to insanity!
