Hi guys. I need some help adjusting my levels. Last year things went pretty smoothly but I'm having to do more adjustments this year & could use some advice.
I have an 18'x52" above ground pool with a SWG & sand filter system.
My water is bright green & cloudy. Here are my most current test readings with an hth strip.
TH - 200
FC - 0
pH - 6.8
TA - 180
CYA - Just slightly above 0
And my swg indicates that there is sufficient salt in the pool.
Can you give me some advice on how to go about correcting these? Thank you soooo much!
TH - 200
FC - 0
pH - 6.8
TA - 180
