The HP flow spec is 30-70 GPM.
So in theory I should be within spec on low speed.
This is what AquaCal told me in another post when I was worried about something else the PB wasn't doing correct.
"The normal flow rate through the AquaCal heat pump is 30-70 gpm., 50 gpm being ideal. This is the range of proper efficiency. As you already mentioned, higher flow rates will decrease efficiency"
So it seems like I can/should get my HP to work with my smaller pump, but in all reality the PB should have sized me for a 1.5 HP - very little difference in efficiency but perhaps enough increase to get closer to the optimum 50 GPM.
