- Jul 8, 2011
- 30
Hello Jason,JasonLion said:The exact amount of R-0870 powder used is not critical. The goal is to add more than you really need rather than using too little. Using too little R-0870 powder can throw off the results of the test. You need to use enough to bind to all of the chlorine that is present. Adding extra, within reason, has no effect. At very high FC levels it is likely that you will need to use more than the normal amount.
I just received my first Taylor K-2006 today and the little dipper appears to be broken. I'm assuming it should look like a miniature teaspoon, but mine is cut off. I was still able to load it with R-0870. based on your note above, do you think it's okay to trust it until a replacement arrives?
