Hello Everyone
I thought I would post my initial results. I am going to Anthony Sylvan Pool center tomorrow to bring a sample as well, to double check myself.
I purchased the TF100 "XL" test kit. This is my first time using any pool test kit. I have an engineering background, but that was long ago!
My numbers, as far as I can tell are as follows:
Chlorine (don't know if it's FC, CC, or TC):
.5
PH
6.8
TA
70-80
Tested positive for Calcium. (This is the only test I did not understand, so no specific numbers)
CYA
40
There is still some leaf matter in the pool. This should be finally gone tomorrow morning. There was quite a bit when I first opened. I think the lawn guys (fired now for other reasons) blew a lot under the cover.
I used the Anthony Sylvan Pool opening kit, for the size of my pool, including "Quick Shock", "Pro 60 Algaecide", and "Les Iron".
I also added what I believe to be the correct amount of DE to the nearest skimmer to the filter. But I did this after running the pool filter and above chefs for about 4 hours. (I opened the filter first, and it looked nice inside!)
MY TEST RESULTS, above, are approximately 24 hours after the chems were added.
Heeeeeere we GOOoooo!!
Bernie
.5
PH
6.8
TA
70-80
CYA
40
Bernie
