Butterfly said:Would you give us a walk-thru on how you are doing the FAS/DPD test?
Some folks have been known to use 25ml water and test as 10ml. Don't ask me how I know this
I take my 'chlorine only' tube pool side, stick it in the water upside down with my arm in up to my elbow, invert it to fill, and then take it out. Then I dump out enough until I get to 10ml. I'm careful to fill only to 10ml. Maybe I'm +- 1ml sometimes. Who knows?
I take sample in my house. Put in a rounded scoop of the powder and swirl over some white paper until almost all of the powder is dissolved. I then hold the R-0871 dropper over the test tube and GENTLY squeeze until drops start coming out, about 1 per second. As soon as the solution goes clear, I stop. I cap the bottle. Then I reach for the R-0003. Sometimes by the time I record, grab and uncap the R-0003 and get ready to add it, the solution turns slightly back to pink. Is this the problem? If it turns back to pink, should I go back to adding R-0871 and continue with the FC test? Or is it safe to start adding R-0003 and then test for CC (same method as above)?
