- May 25, 2013
- 1
Hello, i want to move my pump to the outside of my deck. Currently it only has about 4 feet of hose from pool to pump. I need atleast 10 feet to get to the outside of my deck. I called the local pool place and she says thats the max it should be. If i go 10 feet i am gonna run into alot of trouble with pumping/filtering. Is this true? Any other suggestions on how to do this and it work? I cant get down low and crawl under the deck anymore to get to the pump due to my back. So my question is can i extend my pump 10 feet from the pool and it work just fine? If that does work do they make a relocation kit where i can cap off the old valves, cut new holes and put on the outside?
Thanks in advance. It's a 24" round 4 feet deep Intex pool.
