Thread: Question about decking??
    I am starting to plan my deck build for my above ground 15x24 pool. I was thinking about using Trex type composite decking for around one side and also for the main deck.
    Is anyone using composite for their deck around their pool? I have heard mixed reviews, like it gets very hot and also slippery.
    Can you share your thoughts or experiences? Any suggestions or tips would be appreciated.
    Thanks...
    Above Ground Vinyl 15 x 30
    9100 Gallons
    Hayward DE EC 40
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Here is another thread that goes into some detail about Trex.
    http://www.troublefreepool.com/viewtopi ... light=trex
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Thanks Sean, Of course I posted before I searched the boards! I found this one, looks like IM gonna go with a light shaded composite!
    Thansk again...
    9100 Gallons
    Hayward DE EC 40
    SeanB's Avatar
    Mar 2007
    2,622
    No problem. We don't mind answering questions, but with over 45,000 posts, there's a pretty good chance what you are looking for is already here.
    I'll be the first to admint that our search function is not the best - but it will be much better after BUU2008!
    TFP Founder
    stever's Avatar
    Nov 2007
    Escondido, CA (near San Diego)
    285
    Also keep in mind that the trex products (and similar others) are not as strong as ordinary lumber. They recommend that the support joists beneath be closer than for wood. If you don't, over time they will sag in the heat.
    Steve
    Pool: 625 SF Free-Form In-Ground Shotcrete Pool w/7.5' dia spa.(8 jets), 24" raised bond beam (22,500 gal)
    Pentair Equip: Intelliflo VF Pump, MasterTemp 400 Heater, IC40 SWG, Quad DE 100 Filter
    Automation: IntelliTouch i7+3 (+ extender panel), 6 Jandy Automated Valves (S, R, Spa Bypass, Solar, Cleaner, Spillway)
    Other: 75% Solar, Kreepy Kruiser Cleaner, Tan Hip-Hop Diving Board (a bit curved) on 606 Cantilever Base (SR Smith)
    Links: [TFP Pool Build Thread] - [TFP Landscaping Thread]
