Well, if it needs adjusting, you do PH first. The relationship between PH/TA is complex and can be overwhelming... can make you lose focus, usually the TA can wait unless its insanely low.
What is your issue, exactly? How does your water look?
Open pool 3 days ago pump been running since then FC .05-PH 7.4-TA 90-CH 130-CYN 0 HAVE ADDED 5 GAL BLEACH FC IS STILL .05 WATER TEMP 70 water is milky color . Were do I go from here ? Thanks jerry
LAST 3 DAY POOL HAS THESE READINGS FC 3.0- CC 0-TA 100-CH 230-CYN 45- TEMP 80 SHOCKED YESTERDAY 1 LB. CHLORINE FREE SHOCK POTASSIUM MONOPERSULFATE POOL OPENED 2 WEEKS AGO HAVE A NEW FILTER ADDED 5 OZ FILTER AID 1 WEEK AGO. WATER HAS NOT CLEARED REMAINS CLOUDY .CAN ANYONE HELP THANKS JERRY
