We put in a 15,000 gunite pool with quartz last summer and have been using standard chlorine pucks with a chlorine feeders. I am interested in moving away from these and seeing if the BBB method can work. I do have a few questions:
1. Is there ever a need for "shock" or do you just add more bleach?
2. Can you use bleach and chlorine pucks? Basically, I would want to have pucks in the feeder and keep it off until I am out of town and need some chlorine to be automatically added?
3. Is there possible problems with doing bleach and pucks?
4. Is there any amount of time that you should not swim in the pool after adding the bleach?
Thanks in advance for everyone's help. This is a great forum. I wish I found it earlier before constructing the pool and after dumping hundreds at the pool store.
