Thread: cloudy pool, not sure why?
    Mar 2008
    Delaware
    40
    saw it was cloudy yesterday - couldn't see the deep end.
    chlorine was nonexistent - busy at work past 4 days - forgot to test water - my mistake!
    so i added several gallons of chlorine overnight, now water reading are: using taylor drop kit
    TC 5.6
    FC 4.6
    TA 50
    CA 210
    pH 7.0 (been running it low for a few weeks to try to reduce the scale)
    35000 gal, concrete in ground pool with DE filter.
    Just curious on your thoughts why it was cloudy? algae/microorgs/pollen?
    Thank you in advance for your help.
    Noctiss
    Chlorine went to zero, cloudy pool, and CC is 1 says algae to me. Time to shock the pool. If you do it soon it will clear up more quickly than if you let it get all the way to the green swamp stage.
    Mar 2008
    Delaware
    40
    thank jason, shocking now.
    bob
    Noctiss
