Thread: Dichlor and CYA
    Shepherdsville, KY
    21
    Dichlor and CYA
    Good afternoon all! I read it somewhere on this forum or on the PS Forum but now I can't find it.....How much CYA is put into the pool when you use Dichlor? Right now I have no CYA in the pool and I need to shock it, so I figured I would kill two birds with one stone
    33' x 54" AG 29,000 gal, 1.5 HP Hayward Pump, Cartridge Filter, Pool Rover Robot, devoted follower of the BBB method!
    Houston, Texas, USA
    148
    I'm not really positive, but I think 16 oz of dichlor would increase cya by 8 ppm. So basically .5 ppm cya per ounce of dichlor.
    Poor Man's Pool
    Doughboy 18 ft round above ground
    7600 gal with center drain
    Pentair sand filter, 1 HP pump
    50 ppm borates
    "I know just enough to be dangerous"
    Pool Calc Ver 1.41 (Excel)
    Shepherdsville, KY
    21
    Thanks for the quick reply Poseidon!
    Montreal Canada
    326
    Dichlor is 57.3% stabilizer and 64.4% chlorine (sort of), so for a 37854 liter pool (10000 gallons) adding say 260 grams (9.17 ounces) introduces:
    (260 * 0.573) / (37854 / 1000) = 3.94 ppm stabilizer
    and
    (260 * 0.644) / (37854 / 1000) = 4.42 ppm chlorine
    Guest
    For each 1 ppm of chlorine you add with dichlor you are also adding .9 ppm CYA. (Close enough for Government work! )
