Since your not vacuuming, letting the filter "filter" the particles... when is the last time (if any) you added DE to the filter?
And if the water is clear (the third criteria, see my sig). This is sort of a final sign that all of the algae are dead. Since you have a sand filter, adding DE can really speed this up, if everything is actually dead. If the stuff is not dead, the DE won't clear it.SportzTawk said:So I am actually doing the overnight test TONIGHT. After that, I'm hoping the CC level is still 0 and the water is crystal clear so that I can conclude the Shocking process.
After you pass all 3 criteria, then yep back to normal FC level for your cya.SportzTawk said:I guess from that point it will just be getting the levels back to normal?
