- Jun 8, 2011
- 27
Remodeling my pool area, so it's now or never. I'm in desperate need for a cleaner, and just can't justify a robot. Too much to invest in a single item. My question is: is a pressure side with booster pump the way to go? Is it a better overall system by using a booster pump or okay to just use a cleaner that will work fine with using the return lines.
I currently have 3 returns, one on each end of the pool and one in the middle. I was planning on putting a valve on each return to adjust the return and open the middle one full throttle for the cleaner (hope that made sense). Is this suggested, or since I'm remodeling, might as well put in a booster pump for that middle return. Thanks.
