Get a 400k. I have a 400k on a 14,000 gallon pool in Worcester county.
And you wont use near the gas the heat pump peole said you will. Their trying to cook the books to get to to buy a HP. They are figuring that on continuous use.
FWIW, I hava heat pump too. Its junk in April, most of May, and September on. Works fine June-August. I only have propane so I have the HP to use in the summer to keep the chill off. If i had NG on the property, I wouldnt have the HP. NG is cheap.
Since this post is about Natural Gas vs Heat Pumps for NE - there is no choice there. Natural Gas for sure.
However, I am moving from a house that has a pool with Natural Gas to a pool that has Propane and oil for the home, and I am terrified.
Currently (5/2014 and with power at 0.16 cents per kWh) fuel oil is about $31.43 per million BTUs. Natural Gas is $16.09. Propane is $56.04!!!!!!!!!!! Air source HP is $20. Coal is $10.67. Wood is $12.63. Pellets are $19.43.
As you can see, NG beats a heat pump. That means that if you have Natural Gas, solar is stupid, geothermal is stupid. Air source HP is stupid. Wood pellets are stupid. Even cordwood is dumb unless you get it for free.
So this new pool has Propane, and I am near Boston, and I think I should get a HP but keep the Propane inline with in. I even considered an outdoor wood or coal furnace, but that is a lot of work.
The pool is about 50x25 and not deep enough to dive. We like to heat to 88 degrees. We swim almost every day. In the past I have not used a solar cover even though we own one because it is a pain to put on and off, but now that I know more about them, we will start to.
Which HP works best in the colder temps of NE? We like to use the pool from May through October. Knowing my situation and the current $4 per gallon cost of Propane, should I add a HP inline to my Propane? Won't it pay for the $4000 cost in like 1-2 years?
