- Jul 26, 2011
- 115
My last bid came in at $74K, makes me feel much better
It is a 16' x 44' pool (with 8' x 16' being a 10" deep tanning ledge), the pool is a play pool design, so no deep end.
-Building permit
-Excavation and removal of spoils
-16’ x 44’ steel reinforced gunite pool shell according to specified plans
-1/2 “ steel rebar used throughout entire pool shell
-Two 5G color LED underwater pool lights
-Two surface skimmers
-Dedicated vacuum line
-Two Paramount bubblers on tanning ledge
-suction and return plumbing installed for future slide
-Poured in place stamped cantilever concrete coping
-6” band of frost proof waterline tile
-Matching trim tile on step and bench edges
-Automatic safety pool cover with concrete box
-Walk on deck lid kit with stones to match coping for auto cover box
-Diamond Brite plaster finish
-Pentair Intelli Flow variable flow circulation pump
-Pentair Intelli Flow variable flow water feature pump
-Pentair Clean & Clear Plus 520 cartridge filter
-Pentair Master Temp 400,000 Btu natural gas pool heater
-Pentair Intelli Chem chemical automation system, equivalent to BECS unit
-Stenner 45 feed pump
-Pentair CO2 feeder and CO2 tank
-Pentair IntelliZone Ozonator CD-5 without contact vessel
-Levelor electronic autofill system
-Specified gauges, thermometers and flow meter
-SR Smith Swim and Spike volleyball set
-SR Smith Dual Post Basketball set
-Vacuum head & hose, 16’ extension pole, wall brush, debris skimmer net, water test kit
-One spring opening and fall winterization
-Customer training session with ongoing tech support
I have heard from a few people that the Ozonator is overkill mostly used by commercial builders, thoughts?
The Pentair CO2 feeder & tank could also be considered overkill, used mostly by commercial?
The pool is really 16' x 36' if you take out the tanning ledge, is 2 LEDs enough light?
Intelli Chlor Salt System vs Intelli Chem System? I guess the old salt vs chlorine?, but do the systems work about the same? I was told the chlorine model was more exact on how it distributes the chemicals?
Thanks for any advice, I should be in contract by next week.
-Building permit
