- Feb 13, 2013
- 7
In Canada we are lucky to have some very clean salt deposits. in southern Ontario, the salt that gets mined in Goderich is about as good as it gets. There are salt companies that take this clean mined salt and grind it into a powder. This salt is good enough to eat and that is exactly what we do with it. The problem that we have in eastern Canada particularly in Southern Ontario is that humidity turns this nice ground salt not a solid lump in our salt shakers. It is particularly noticeable on our picnic tables or at the cottage. To help prevent this, salt companies add a flowing agent to the salt.
If the salt that is mined is simply ground up like the table salt and put into a bag with no additives, it is sold as pool salt. So pool salt and table salt come from the same place and have the same purity. Table salt has a little flowing agent in it.
Water softeners need a coarser salt to function properly. If you take the same salt that was used for pool salt and press it into pellets, you have water softener salt. It is clean and pure and has no additives. So pool salt, water softener salt, and table salt all start with the same grade of salt. Table salt has flowing agent added and water softener salt is pressed into a larger pellet.
This is where things start to get confused. If you decide to add table salt to your pool, remember that the salt is the same but it has flowing agent so in some cases you may get staining on your pool. It typically comes out as a grey ring around the pool. Water chemistry needs to be correct for this to actually happen but it is something to keep in mind. Water softener salt is just as pure as pool salt so it can be used in place of pool salt. Once again there are a couple of things to keep in mind. First there are different grades of water softener salt. If you can look at the salt in the bag it is pretty easy to tell which one is the clean salt. If the salt in the bag looks like road salt with pink and grey and brown lumps in it, don’t put it in your pool. These are impurities like manganese and iron and they will stain your pool and discolour the water. If you look in the bag and the salt is just big clean white pellets or chips, it is good to use. The bag itself will confirm this by saying the salt is better than 99% pure sodium chloride. This salt can be used in your pool because it is the same salt that they sell as pool salt only a little bigger.
All of the above holds true for salt that comes out of Ontario. There are problems with salt that comes from the American mid-west. In this region there is a lot of manganese and it gives us impurities in the salt that aren’t good for the pool. In these regions you may want to stick with pool salt.
Below are the typical questions that are asked about pool salt
Q/ Can I use water softener salt in my pool?
A/ Yes you can but make sure it is clean salt and doesn’t look like road salt with pink and brown lumps
Q/ Salt in my water softener stays there for a long time before it dissolves. Will the same thing happen in my pool?
A/ Yes water softener salt takes longer to dissolve but if you dump it in the shallow end of the pool and brush it around it will be gone relatively quickly. If you have a pump return jet on the step of you pool, simply dump the salt on the step and it will all be gone within two hours.
Q/ Why would I want to use water softener salt in my pool?
A/ It is usually about half the price of pool salt.
Q/ My pool store said that using salt other that pool salt will void the warranty of the salt chlorinator.
A/ No the warranty isn’t void with a Watermaid unit.
Q/ My pool store said that using salt other that pool salt will ruin the liner.
A/ No it wont ruin your liner. If you take note of what was said above, it is the same salt so how could it cause problems that pool salt wont.
Q/ Why was I told that you have to use the proper pool salt?
A/ I’m not sure. They either don’t know, or there is more money to be made by selling “pool” salt.
