dmanb2b:
The secret here is that the pool is indoors and doesn't need the stabilization of the CYA. Regarding maintaining the observation that it is "easier to maintain FC in the 2-3ppm range, rather than trying to manage FC levels at precisely 0.5-0.75ppm" comment, it is quite easy in a 2000 gallon pools to maintain the FC at .5 ppm: Once the cloudiness issue is resolved (and I'll stand by my 3 day estimate), adding 3 ounces after each swim and checking the FC the following day before swimming is really pretty simple. If the FC level is a bit higher (say 1.0 ppm), cut back on the amount you add. Simple!!
Here is what Endless Pools has to say on the subject:
26.6 Oxidation and Chlorine Requirements
The Nature 2 system included in your pool kit significantly reduces the amount of chlorine you’ll need to
use. This purifier adds silver and copper to the pool, which will kill bacteria and algae in the water. However,
it does not oxidize or “burn-up” small particles of debris in the pool. Maintaining a minimum level of 0.5
ppm free chlorine in your pool at all times is necessary. Adding 1/2 cup of Clorox a day will add about 0.5
ppm of free chlorine to a standard sized pool. How quickly that chlorine is consumed depends upon water
temperature, bather load, and the amount of direct sunlight the pool receives.
a. Chlorine Stabilizer and Outdoor Pools
Your Taylor test kit comes equipped with testing procedures for cyanuric acid. Cyanuric acid is a chlorine
stabilizer, meaning it protects chlorine from getting broken down by sunlight. If your pool is located
outdoors, we recommend using the granular form of stabilized chlorine (Should have an active ingredient of
sodium dichlor) instead of Clorox. Another option would be to supplement Clorox by adding cyanuric acid.
Either method will necessitate testing for cyanuric acid every two weeks. These chemicals are readily
available at any pool supply store.
b. Chlorine Stabilizer and Indoor Pools
Many customers are sold a stabilized chlorine product for use in their indoor Endless Pool. Endless Pools
would not recommend this practice, as Clorox bleach is ideal for this setting. Using a stabilized chlorine
source is more expensive, and it also requires the periodic testing for cyanuric acid levels. If the level gets
too high, it can render the chlorine ineffective, and it may necessitate the partial draining of the pool in order
to lower the levels.
Regards,
Swan
