rhharmon said:
My CYA is now at 40 ppm because I've been vacuuming to waste. Tested tonight before I added water (due to vacuuming to waste) 21.5 FC; 0 CC. Pool looks much better. Still have algae but I know it's starting to diminish. Tested the CYA this morning (40). I can't seem to bring the water temp up to 70 deg; My house temp is only 70 deg. So tried putting under covers and eventually got it to 68. Tonight tested after 30 mins of adding bleach (and scrubbing walls and bottom) and it's now at 25.5 which is above mustard algae level, but I added what the calculator told me to add. Again, I'm learning but feel like I'm finally making SOME progress.
Sounds like you are definitely making some GREAT progress.
Keep up the good work.
It is most certainly a learning experience, as with anything, but this one is fun.
Yay, lower CYA! Wohoo!!
You can now drop down to 16ppm FC for shock @ that CYA level.
Just shoot a bit higher to be sure it stays at or above 16.
You'll use less bleach this way, which saves you mooola. :-D
Hrmmmm can't get the sample temp up, huh?
What if you set it in the sun?
I don't think we can put the sample in the nuker-wave, but I'll ask, HAHA!
Instead...
Put it in the CYA mixing bottle, just up to the bottom of the sticker, then seal it up. Now this may sound funny, but hey, it'll work.
I like your covers idea, so try this instead.
Now stick it under your armpit and clamp down, use your 'legpit' if you want, or alternate.
That'll warm it up nice and quick. Give it a gentle shake, slosh, like with the pH tube to distribute the heat.
It also sounds like your bleach percentage may be higher than what it says on the bottle.
If you're buying generic bleach, try entering 8% in the calculator, where it says 6% at the top.
It could be even higher, but experiment with it and you'll figure it out. We humans are pretty durn smart when we put our minds to it. *winks*
Oh, for purposes of pool volume, do you have an Intex AGP, Doughboy, Hayward??
