- May 4, 2011
- 634
Since I will be closing within the next month I started looking at accessories. Plus I have to buy a winter cover since mice keep getting in to my shed and tearing up my covers.
So far I've only lost 1 solar cover and 1 winter cover, both had been used two seasons. This time I will try to find a Rubbermaid tub big enough to fold the covers in to.
My question is this - in the past I haven't used a pillow, everything seems to work fine with the exception of opening in the spring. Some leaves/debris always end up falling in to my clear water! If I'm using an air pillow I would assume this will be less of a problem since the water and debris will be collecting around the edges. If I'm easily able to clean it out from the sides would a leaf net even be worth $80..? Opinions/suggestions, thanks.
