Quick question:
For the past month I've been adhering to the pool calculator and CYA charts for all my chemical balancing...and have been using the Taylor K2006 test kit for testing.
With a CYA of about 60, the chart tells me I should be around 7ppm FC.
I just looked at the Walmart HTH brochure (which I bought a long time ago), and it says going above 4ppm FC can cause bodily injury and that you are using more FC than needed.
Can someone explain why the test kit brochure says not to go above 4ppm FC, and the CYA chart says to go nearly double that amount?
Thanks!
Thanks!
