The CEC database has all versions and they are all the same. You can look the data up here:
[tr:c2tepm9b][td:c2tepm9b]
Manufacturer Name
[/td:c2tepm9b][td:c2tepm9b]
[center:c2tepm9b]Brand Name[/center:c2tepm9b]
[center:c2tepm9b]Model Number[/center:c2tepm9b]
[center:c2tepm9b]Speed RPM[/center:c2tepm9b]
[center:c2tepm9b]Pool Pump Motor Capacity[/center:c2tepm9b]
[center:c2tepm9b]Motor Service Factor[/center:c2tepm9b]
[center:c2tepm9b]Motor Efficiency %[/center:c2tepm9b]
[center:c2tepm9b]Nameplate HP[/center:c2tepm9b]
[center:c2tepm9b]Curve-A gpm Flow[/center:c2tepm9b]
[center:c2tepm9b]Curve-A Power Watts[/center:c2tepm9b]
[center:c2tepm9b]Curve-A Energy Factor[/center:c2tepm9b]
[center:c2tepm9b]Curve-B gpm Flow[/center:c2tepm9b]
[center:c2tepm9b]Curve-B Power Watts[/center:c2tepm9b]
[center:c2tepm9b]Curve-B Energy Factor[/center:c2tepm9b]
[center:c2tepm9b]Curve-C gpm Flow[/center:c2tepm9b]
[center:c2tepm9b]Curve-C Power Watts[/center:c2tepm9b]
[center:c2tepm9b]Curve-C Energy Factor[/center:c2tepm9b]
[/td:c2tepm9b][/tr:c2tepm9b][tr:c2tepm9b][td:c2tepm9b]
Hayward Pool Products
[/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]EcoStar[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]HCP3400VSP[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1000[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2.7[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]33[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2.7[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]20[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]88[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]13.64[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]12[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]80[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]9[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]28[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]96[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]17.5[/center:c2tepm9b][/td:c2tepm9b][/tr:c2tepm9b][tr:c2tepm9b][td:c2tepm9b]
[/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]EcoStar[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]HCP3400VSP*[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3450[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2.7[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]84.3[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2.7[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]71[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2005[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2.12[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]42[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1651[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.53[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]98[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2324[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2.53[/center:c2tepm9b][/td:c2tepm9b][/tr:c2tepm9b][tr:c2tepm9b][td:c2tepm9b]
Pentair Water Pool and Spa
[/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Pentair[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]IntelliFlo Variable Speed[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]800[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3.96[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.32[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]92[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]18[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]110[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]9.82[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]11[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]105[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]6.29[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]24[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]110[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]13.09[/center:c2tepm9b][/td:c2tepm9b][/tr:c2tepm9b][tr:c2tepm9b][td:c2tepm9b]
[/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Pentair[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]IntelliFlo Variable Speed*[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3450[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3.96[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.32[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]92[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]71[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2340[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.82[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]43[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1990[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.29[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]97[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2720[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2.14[/center:c2tepm9b][/td:c2tepm9b][/tr:c2tepm9b][tr:c2tepm9b][td:c2tepm9b]
[/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Pentair[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]IntelliFlo VF[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]800[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3.96[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.32[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]92[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]18[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]110[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]9.82[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]11[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]105[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]6.29[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]24[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]110[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]13.09[/center:c2tepm9b][/td:c2tepm9b][/tr:c2tepm9b][tr:c2tepm9b][td:c2tepm9b]
[/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Pentair[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]IntelliFlo VF*[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3450[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3.96[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.32[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]92[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]71[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2340[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.82[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]43[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1990[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.29[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]97[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2720[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2.14[/center:c2tepm9b][/td:c2tepm9b][/tr:c2tepm9b][tr:c2tepm9b][td:c2tepm9b]
[/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Pentair[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]IntelliFlo VS+SVRS[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1100[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3.96[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.32[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]92[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]24[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]145[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]9.93[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]15[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]132[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]6.82[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]33[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]150[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]13.2[/center:c2tepm9b][/td:c2tepm9b][/tr:c2tepm9b][tr:c2tepm9b][td:c2tepm9b]
[/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Pentair[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]IntelliFlo VS+SVRS*[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3450[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3.96[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.32[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]92[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]71[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2340[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.82[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]43[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1990[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.29[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]97[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2720[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2.14[/center:c2tepm9b][/td:c2tepm9b][/tr:c2tepm9b][tr:c2tepm9b][td:c2tepm9b]
[/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Pentair[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]IntelliFlo VS-3050[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]800[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3.96[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.32[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]92[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]18[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]110[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]9.82[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]11[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]105[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]6.29[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]24[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]110[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]13.09[/center:c2tepm9b][/td:c2tepm9b][/tr:c2tepm9b][tr:c2tepm9b][td:c2tepm9b]
[/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]Pentair[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]IntelliFlo VS-3050*[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3450[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3.96[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.32[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]92[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]3[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]71[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2340[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.82[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]43[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1990[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]1.29[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]97[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2720[/center:c2tepm9b][/td:c2tepm9b][td:c2tepm9b][center:c2tepm9b]2.14[/center:c2tepm9b][/td:c2tepm9b][/tr:c2tepm9b][/table:c2tepm9b]
