Thread: Pump Questions
    May 2008
    rock springs, wi
    45
    Pump Questions
    I am looking into getting an 18x33 oval AGP. It appears that the recommended pump will be in the 1/2 hp range. Will that be strong enough to vacuum the pool (sand filter)? Is a two speed pump in that size a feasible alternative?
    27' AGP with 6' deep end (AquaLeader); 3/4 hp, 2 speed pump (Pentair); 22" sand filter (Pentair Sand Dollar); 2 4x20 Solar Bear panels with Goldline control valve
    i would use a 1hp powerflow pump made from hayward
    JoshU's Avatar
    New Orleans, LA
    542
    Re: Pump Questions
    Quote Originally Posted by bobnamy
    We should really know how many pounds of sand the filter will hold to size it properly...
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
