SECTION320
WASTE WATER DISPOSAL
320.1 Backwash water or draining water.
Backwash water and draining water shall be discharged to the sanitary or storm sewer, or into an approved disposal system on the premise, or shall be disposed of by other means approved by the state or local authority.
Direct connections shall not be made between the end of the backwash line and the disposal system.
Drains shall discharge through an air gap.
Water from pool or spa filter system backwashing or from draining a pool or spa must be disposed of in a sanitary sewer system, in a storm water system, in an approved disposal system on the premises or in accordance with the requirements of the state or local authority.
Backwash drain lines and drain lines must not be directly connected to the point of disposal [see Commentary Figures 320.1(1) through (3)].
codes.iccsafe.org
Digital Codes
ICC Digital Codes is the largest provider of model codes, custom codes and standards used worldwide to construct safe, sustainable, affordable and resilient structures.
