Been lurking and reading here for a while. Just had an old AO Smith pump replaced with one of the new Jandy VS FLoPros but the plumbing on the output side seems a little restrictive (note the three 90s in a row forming a horseshoe into almost an S).
It would seem to me they could attach the base-plate/riser that came with the pump which would raise it enough to use a single 90...
So is this going to cause a restriction or is it just cosmetic?
