I've got my Intelliflow connected to my Jandy system and it works pretty well, but I've noticed if I open the system to clean the pot and restart it, it will attempt to prime for a few seconds (spin up to a high rpm) and then stop with an error. If it would run for about 10 seconds more, it would prime fine. As it is, when the error goes away, the next time it primes, as it created enough vacuum to pull water into the system for priming.
My question is, if there is an error on the Intelliflo and I want to clear it, how do I do that? With it connected to the Jandy, the display controls are "inactive" and therefore I can't reset the pump like I would if it were running in a standalone mode.
Can I clear the error through the Jandy iAqualink menu?
Thanks...Russ
Thanks...Russ
