What is the margin of error on the OCLT? I guess I could just do the FC test 5 times with the same sample and see how much variation there is, but someone has probably already done this, so I'll just ask you.
You can lose 1 FC and pass.TomAtlanta said:What is the margin of error on the OCLT? I guess I could just do the FC test 5 times with the same sample and see how much variation there is, but someone has probably already done this, so I'll just ask you.
As Robbie said, if you have algae, you should get rid of it or it will just keep consuming your chlorine.TomAtlanta said:I can live with a little algae.
My plaster is also pitted.
I agree with RobbieH...unless the pool guy is claiming it is the wrong sand, I see no reason to give him your money for his "new" sand.
He said the stuff I thought was either dust or mustard algae was probably old paint oxidizing.
Everything but the algae seems reasonable.TomAtlanta said:I know you can only guess without seeing the pool, but does this seem reasonable?
