Thread: jandy vs pentair valves
    Which valves are the best to use. I want to be able to control the water flow thru the valves. The pentair valves have stops that allow you to divert water @ different flow rates. Does the jandy valve allow you to do this (ie. keeping the valve @ half open without the valve slipping back full open). Also the jandy are CPVC and the pentair can be bought CPVC or PVC. Is it an advantage either way? I will have valves on all returns, skimmers, md, & waterfall.
    chhtx
    Dec 2007
    Central New York
    504
    The Jandy valves can be locked in the position you want. IMHO, the Jandy Valves are better.
    I just bought 8 of them for redoing my pool shed. I put a valve on everthing. I use them to increase from 1 1/2 inch pipe to 2 inch pipe; like a reducer.
    I bought them from here; received them fast and well packed.
    http://www.westsidewholesale.com/index. ... 1.4777@@@@
    They carry both lines of valves.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Here is a tip for Jandy valve owners:
    Take the valve apart(unscrew all those screws) and lube
    the seal O-Ring and the O-Ring on the handle shaft. This will prevent
    air leaks in the valve.
    Cliffs
    Sep 2007
    Toronto
    106
    Quote Originally Posted by cliff_s
    Cliffs
    On my Jandy Valve, it says NEVER LUBE.
    OH TWINS
    San Juan 8500 gal Fiberglass Pool, Sta-Rite Max-E 1 HP pump, Star-Rite System 3 Cartridge Filter 300 sq. ft,
    Sta-Rite Max-E 200,000 BTU gas heater, Aqua Logic SWG with P-4 panel. Goldline wireless remote control,
    3 Jandy Neverlube Valves with Goldline motorized control, iRobot Verro 500 pool cleaner
    5 Poolstar 1000 LED Lights, LED strip light at waterfall, Prozone Ozonator PZ7 with degasser column,
    Jandy Auto Waterfill, Aquamatic motorized pool cover, Poolbuster Max CC handheld vacuum.
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    I've noticed that a lot of builders who use Pentair as their primary equipement brand for pumps, filters, and cleaners often use Jandy valves.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
