I didn't see any answer to this...CraigMW said:And you have set the "Impedance Magnification Selection" to the correct position? You might want to check the nominal resistance across the two input terminals for each side (e.g. set VOM to Ohms, and touch the red and black terminals for left and then right speakers). You should see a resistance around 5-8 ohms. Any lower than this, and your amp is seeing a short circuit and kicking in the safety circuit to prevent damage to the amps.
twmackey said:I need to check with hifi shop I do my Business with and ask them. I did buy the niles speaker secector from them. I have talked to other people in the business and they have all said when you are pushing that many speakers you should have an amp that can push it. My wire als is 14 guage direct buriel out in the yard and 16 guage on the deck.
I agree that the receiver is totally incapable without the special speaker switch... But with it (setup correctly) it will not see the massively parallel load.twmackey said:The receiver is really not a amp, so it may not take the of all those speakers. But a dedicated amp capable handing the ohms and wattage is probaly what I need. The Niles SI 2130 amp can handle the load.
