Our Sylvan in ground pool leaks about an inch of water per day and after fixing and ruling out several other possibilities we believe the leak to be in the recessed Sylvan light fixture. I saw some pictures of the Sylvan light in another thread and was wondering if the leak is determined to be where the wires penetrate the pool wall (with a food coloring dye test) how best to plug and seal the leak?
I was thinking of leaving the wires intact and applying epoxy putty around them at the wall should that be the location of the leak.
