Results 1 to 7 of 7
Thread: Need info on waterfall build...
    reef n ale's Avatar
    Mar 2008
    Mushroom Capital of the World
    43
    I haven't talked to my PB about this yet because I wanted to see what you guys think.
    I'm having a small waterfall done and my PB is using a shelf to build it on. The stone that sits in the shelf will be sitting in about 3-4" of water.
    I came home the other day to find the gunite shelf coated with what I think is tar. I'm at the stage of just gunite-no tiles or coping yet.
    Does this sound right or normal???!!! Tar???!!!
    I'm at at loss as to how this should go and how it fits into the pool build.
    Please help!!!
    Rob
    25000 Gals, Intellichlor IC40 SWG , Intelliflo 4X160, Pentair Cartridge Filter, Easy Touch 8, Polaris 280
    My adventure: my-new-pool-build-t4534.html
    stever's Avatar
    Nov 2007
    Escondido, CA (near San Diego)
    285
    The gunnite is not considered waterproof -- it will let some moisture through. The plaster makes the pool water-tight. if the rocks will be placed on the gunnite, there would be no plaster in this area. My guess is that the 'tar' is to seal the gunnite from water getting through (in or out). Our PB said they seal the shotcrete behind stone veneer on a raised bond beam to keep water from hitting it from behind and causing efflorescence.
    Steve
    Pool: 625 SF Free-Form In-Ground Shotcrete Pool w/7.5' dia spa.(8 jets), 24" raised bond beam (22,500 gal)
    Pentair Equip: Intelliflo VF Pump, MasterTemp 400 Heater, IC40 SWG, Quad DE 100 Filter
    Automation: IntelliTouch i7+3 (+ extender panel), 6 Jandy Automated Valves (S, R, Spa Bypass, Solar, Cleaner, Spillway)
    Other: 75% Solar, Kreepy Kruiser Cleaner, Tan Hip-Hop Diving Board (a bit curved) on 606 Cantilever Base (SR Smith)
    Links: [TFP Pool Build Thread] - [TFP Landscaping Thread]
    Jan 2008
    Forney, TX
    162
    The shelf is going to be below the waterline? Is there some kind of a step beyond the stone? The coating is probably as Steve said, to waterproof the surface of the gunite. Our PB used a coating over the gunite shelf under our waterfall and grotto as well, but the shelf on ours was above the waterline. If yours is below the waterline, water will seep through under the stone. Hopefully they've got a shelf behind the stone to contain the water.
    Our pool adventure... click here
    reef n ale's Avatar
    Mar 2008
    43
    Thanks for the replies, guys!
    Here is a closer pic of the shelf before the tar coating. I'm estimating the stone will be sitting in about 3" of water.
    Does this all make sense?
    It's raining here today, so I'll try to get a pic with the coating tomorrow.
    Jan 2008
    Forney, TX
    162
    Good, they do have a containment curb behind the shelf. That should work fine. Did they turn the waterproofing material up the curb at the back?
    reef n ale's Avatar
    Mar 2008
    43
    Yes, the bottom of the shelf and the curb up the back is all covered. I guess I'm trying to find out about the choice of material used.
    Will tar sitting in water last? Will it do anything funky to the water?
    Rob
    Jan 2008
    Forney, TX
    162
    I doubt it's tar, it's probably bituminous waterproofing. It's used all the time in roofing, but I don't know if that's a widely accepted product for use in pools. If you're concerned about it ask your PB what they used and discuss it with them. If still concerned, find out the exact product and look it up online.
