Results 1 to 8 of 8
Thread: Excavator not digging steps is this right???
    My pool dig started this morning but they had to stop it due to rain. They only got a portion of the shallow end cut out and I saw there were not steps shaped out where they were to be. I questioned one of guy who is doing my rebar, gunite about this and he said they totally shape the steps in with gunite. is this right??? From from I have read the top step mound is left in place with dirt. Any thoughts?
    Owner/Builder- Pool under construction- Started 4/18/08
    20X40 freeform 3 1/2" to 8 1/2' deep
    elevated 8' spa w/ spillover
    Plaster: Undecided
    Pentair intelliflo
    Pentair intellichlor
    Pentair Mastertemp 400,000 BTU gas heater
    Pentair Triton II 30" sand filter
    LED (probably colorlogic) 3 in main pool and 1 in spa
    Polaris 280 w/ booster pump
    Control System: Still working on this Intellitouch I guess but don't know all the components I need yet.
    reef n ale's Avatar
    Mar 2008
    Mushroom Capital of the World
    43
    I believe that is correct.
    A lot of extra gunite is generated while the shell is shot. They will use this "extra" gunite to build up and shape the steps.
    Rob
    25000 Gals, Intellichlor IC40 SWG , Intelliflo 4X160, Pentair Cartridge Filter, Easy Touch 8, Polaris 280
    My adventure: my-new-pool-build-t4534.html
    Sep 2007
    Austin, TX
    25
    I seem to remember a post about using 'extra' gunite on steps. It was a link that showed that gunite failure was largely caused by moving extra shot gunite, after it had been slightly set, to form steps and seats. I couldn't find the post when I searched.
    16 x 32 IG Vinyl
    Sand Filter
    Jul 2007
    Sahuarita, AZ
    278
    I know both mine and a friends pool was built in this way, with the steps formed entirely out of gunite.
    My Pool:
    12K gal IG gunite with 7' raised spa, gunite waterfall, PebbleTec Caribbean Blue finish, solar heating & in-floor cleaning system
    Equipment: Sta-Rite 300' Cartridge Filter, Intellichlor IC20 SWCG, Sta-Rite 400k BTU heater, Intelliflow 4x160 main pump & Sta-Rite 3/4 hp waterfall pump, EasyTouch controlls w/ wireless controller, TF-100 Test Kit w/ salt test.
    Oct 2007
    Philadelphia, PA
    86
    Here's a link to the post on using rebound. It seems like this is a very bad idea.
    http://www.troublefreepool.com/viewtopic.php?t=3643
    11x27 in ground, vinyl pool
    ~12,500 gal
    PAC FAB (Pentair) Pinnacle 3/4 hp pump
    Pentair 24 sq ft DE filter
    One skimmer, one return (no main drain)
    Sep 2007
    Lafayette, Louisiana
    344
    There's a difference between using "rebound" and just forming the steps with gunite.
    I would request they not use rebound material to form them, but just form the steps with the fresh gunite as it comes out. I believe that is a common practice for smaller steps and ledges. I have a couple small ledges on the deep end of my pool that were formed as an afterthought. They sprayed them on and built them up after the wall was shot. The larger/longer steps and benches were cut from the ground and the rebar cage formed.
    Fortune favors the well prepared
    The build...
    viewtopic.php?t=3974
    Freeform 24' x 38' IG gunite. 3 1/2' to 8' deep. 28,500 gallons. AutoPilot Total Control SWCG. Pentair Intelliflo VF. Pentair CCP520 cartridge filter. Colorlogic LED lights. Tahoe Blue Diamond Brite. 1200 sq ft stamped concrete deck.
    More details as they happen...
    Ok, i'm breathing easier. Thanks to all for feedback
    Ok, thanks for the feedback. I am breathing easier now. He is using fresh gunite, not rebound so I am OK with this.
    Plaster: Undecided
    Pentair intelliflo
    Jan 2008
    Forney, TX
    162
    Ditto the above on my pool. They left dirt in under our baja shelf, but didn't for the pool steps. Like you I got concerned about it. I called the super and he explained that they shoot it in solid gunite. Sure enough they formed the steel for the steps and the steps were solid gunite by the time it was said and done. No worries
    Our pool adventure... click here
