Good morning!
I'm excited to be converting, and thank you for this wonderful board / community! I will be sure to take some pics and post during the process ...
Quick Background: My pool has not yet been opened, I'm in the planning / recon stages . I noted that the filter sand will need to be changed AFTER I've successfully stabilized chlorine levels. Currently, my filter is EMPTY and sitting in my basement since I planned to put new sand in this season ...
My question is this: Since this is new sand, do you recommend that I change the sand again after chlorine stabilized as indicated in the conversion steps, or will the sand still be good to go since it's kind of new? Or if brand new, 2nd batch of sand will still be needed, any suggestions on how I might "plug up" my pool while I disconnect filter and re-sand it again?
Thanks again!
Thanks again!
