So I did bring my CYA down to about 50, but I just was reading around and saw that if your pool gets a lot of direct sunlight (I live in Houston, TX and it's starting to get hotter and my pool is in direct sunlight for probably 70% of the daylight hours), you might want to bump the level up to 70-80. I'm using bleach to chlorinate my pool now, but as stated in the original post, I do have the in-line feeder with tri-chlor tablets. Should I use some of those to raise my CYA back up a bit? I don't think it's an emergency, but I thought if it would help something I'd go ahead and use some of those to bring the level back up some (instead of buying CYA and adding it specifically).
Any thoughts? Will the higher CYA cause me to use more bleach this summer? I'm not really sure what the idea behind having a higher CYA is.
