I have a salt water pool and my pool supply store had me put stabilizer in my pool back in October. The problem is and has been, it hardened into a blockage in the piping and can't get it unclogged because water temp was not high enough to dissolve the stabilizer. I have tried cutting main drain and other skimmer off and pumping thru the clogged skimmer pipe, ice picking the stabilizer clog, and pouring hotter temp water thru a funnel directly on blockage with no results. Hs anyone else solved this problem? Don't want to wait till pool water temp gets to 90 degrees.
