Ok I began to empty water from the pool, I noticed that if I was going to let out that much water then I might as well go all the way. I did some repair to the steps with Leslie's cement, replaced the light, I noticed that all the sediment in the water was from the walls of the pool, so I emptied the pool, acid washed the walls, rinsed the pool, and repainted the surface with three coats of insulx water-born paint, I cannot afford a re-plaster at this time. I let the paint cure for 7 days and now I have almost fully refilled the pool.
What would be the correct steps to ensure healthy water and chem levels from this point? I am just finally going to order a real test kit, can I get started with my wal-mart kit? all suggestions welcome......
