I'm considering getting a new pool cleaner and changing the plumbing a bit, but first, let me define the current setup:
If possible, I'd like to use this separate 1" line for a pool cleaner because:
Based on this, I have a few questions:
1. Is it safe to use this 1" line? Or is it too small which could cause issues with debris clogging it?
2. I'm looking at The Pool Cleaner based on reviews at this site. Should I consider getting the pressure-side cleaner, avoiding any issues with the 1" line clogging?
3. Do pressure-side cleaners just move small debris (small enough to flow right through the bag) from one part of the pool to another? Or will the bottom drains pick up a lot of this smaller stuff as it settles toward the deep end?
4. If I go with a new suction-side cleaner (or just keep my existing G2), I'm thinking about adding a valve on the pool suction line so that I can adjust flow between the 1" cleaning line and the skimmer/bottom drain line so that I can use my pool pump to run the cleaner as opposed to a separate pump. Would that be an acceptable option?
5. Are there any other complications I haven't thought of yet?
- - I have a Baracuda G2 suction-side cleaner that is attached to the skimmer using a Vac Mate.
- I don't have a separate pump for my cleaner.
- The plugs at the bottom of the skimmer are capped, meaning that the bottom drains for the pool and spa are not active.
- The skimmer is located at the deep end of the pool, which makes it harder for the G2 to clean the shallow end.
- There is a separate 1" line from the pool (midway between the deep and shallow ends) that ends by the pool pump. My guess is that the previous owners had a separate, auxilliary pump at one time that used this dedicated 1" line for a cleaner.
- - I'd like to have the skimmer focus on skimming rather than share itself with the pool cleaner.
- I'd like the bottom drains to work, especially in the hot tub, to suck debris out.
- A more centrally-located cleaner location should improve cleaner performance.
- If I set everything up correctly, my system will clean when in "clean" mode, skim when in "skim" mode, etc. This "may" allow me to set my VS pump at a lower setting if all suction is set to the 1" line for clean mode.
- I've got a 1" line there, why not try to use it.
