- Mar 3, 2012
- 5
Opened the pool last week and water now looks very good. Received my test kit and here are my first test results:
Filter Pressure: 16
Water Temp: 57 F
Free Chlorine: 4
CC: 0
pH: 7.4
TA: 50
CH: 140
CyA: Less than 30 (too low to read)
Salt: 1300
I know I am low on the Salt, CyA, TA and slightly on pH. Assuming 60* F water is too low to generate chlorine, but my cell lights are all green and FC levels look pretty good.
Used the Pool Calculator to determine what to add, but need to know what order I should proceed. I am assuming you make 1 add at a time and then retest before proceeding due to the interactions on multiple parameters from adjustments??
Love the forum and have learned a ton from reading the posts.
Thanks for the help.
Filter Pressure: 16
Water Temp: 57 F
Free Chlorine: 4
CC: 0
pH: 7.4
TA: 50
CH: 140
Salt: 1300
