Thread: distance from pool to house?
    im getting ready to install an 18" agp and i want to know what is the minimum distance from the house i can install it. my back yard is not very big and the closest i can install is the edge of the pool being about 7 feet away from the house. is that good enough or do i need to go further?? i wouldnt mind further out so i can get maxium sun but dealing with a steep slope is already bad enough. with the pool being about 7' from the house, ill get about 7 hours of sunlight before the house starts blocking it. the pool will be mostly facing east and a little to the south, with the house on the west side.
    18' 52" deep laguna agp with pentair 1 1/2 hp pump and 22" filter, intex swg
    DaveNJ's Avatar
    Toms River, NJ
    520
    The town usually has set back requirements and other things fencing, electrical etc.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    Jan 2008
    Burbank, IL
    109
    That's right, check with your town. In mine it's only 3 feet.
    Wilbar 12 x 17 Buttress Free AG (~4400 Gal?)
    Hayward 225 sq ft cartridge filter
    1/2 HP Pentair Whisperflo
    Liquidator chlorine feeder
    Pool Rover Jr.
    BBB - it's the way to go
    Mar 2008
    Frisco, TX
    24
    In our town the rule is you need to be as far away from the house as the depth of the pool. So, if your pool is going to be 6 ft deep you need to be at least 6 feet away from the house.
    ok i think i can find a way to put it about 16 ft away from the house. ill have to put up my deck first and see where i can work the pool into it. the end of the deck will be about 16' away from the house. i just want a general rule of how far away from the house it should be. if not, it will be at least 6-8 ft away. it is an 18' wide 52" deep pool.
