We are in midst of big renovation for 30,000 gallon inground pool. Contractors will replace all equipment and I just wanted to run specs by you all to make sure they aren't cutting costs.
For the pool, they have a 1.0 HP Jandy PHPF (+5 deck jets)
Filter is being changed from a sand to Jandy CV 340.
Is this enough HP and area for the pool + jets? Also, we have bedrooms above the filter and I want to be sure it's as quiet as possible. Would you recommend a stealth? DO we need water feature pump separate?
Thanks in advnce
Thanks in advnce
