Just purchased a Hayward EcoStar. How do you get to the Timers Menu? I able to get the configuration menu up to the point where it says "Use Timers Menu to set timeclocks" but none of the keys (<,>,+,-) do anything after that point.
My mistake. On the EcoStar pump once the menu is unlocked (holding <> at the same time) you scroll thru each top level menu by selecting the menu button (1x for Config. 2x for Timer, ..). Then you can use the <> to scroll thru that paticular menus options.
