I had two old T104's wired together, one timing the pool pump, one timing the Polaris pump. When I say "together", the wiring is such that the Polaris pump won't come on unless the pool pump is running. The one timing the pool pump stripped a gear so I decided to replace them both. I figured the safest way for an amature to do this was turn off all the power, label the ends of the wires as I disconnected them, and put them back together the same way. I thought I did--but maybe not.
I got the pool pump right. It's working perfect. I got the clock right on the Polaris, but when I turn it on---nothing happens. This is obvious operator error and I am the operator.
I might can figure this out by myself but it would be a lot easier if somone out there with real expertise in this area could set me on the right track. Basically I need to know how to hook up the Polaris timer. It looks like it has it's own power lines.
