Would the use of tinned copper for pool/spa wiring be considered code compliant? I am having trouble finding any info regarding this in the NEC.
PoolGuyNJ said:Also expect to need a common lead.
PoolGuyNJ said:Also expect to need a common lead. Lights and other accessories on tubs are rarely 240V.
bk406 said:Mx, how far is your tub from the panel? What are you going to run on your tub? Pump? Lights? heater? The power needs and distance will dictate what you need to run for wiring. Are you running the power from an exising subpanel outdoors? From Inside? More detail will help here.
bk406 said:Ok, you can use #6 stranded copper wire. Not sure why you want the tinned copper, its not needed.
