I am a new pool owner and am frustrated with our brand new Jandy LXi gas heater. Our pool is a little over a month old and we have not been able to use the heater yet. When you fire it up, it seems as if it is going to work and heat does come out of the top and then after a few minutes it stops and we get a FAULT-CHECK IGN CONTROL code. We have gone back and forth on where the problem originates...first we were told the meter was too small. We replaced that. Then the regulator on the meter was thought to be too small, so we had the gas company replace that. Jandy has had 3 service reps out and each says it's a different problem. We do what they tell us to do, but it doesn't fix the problem. This last one today said that the regulator should be installed on the gas line directly on heater unit, in addition to the gas meter itself. Does this sound like a logical step or just more of chasing a solution that won't work? Our gas meter is only for the pool and is only about 25 feet from the pool equipment.
