I am in the process of putting together a liquid chlorine feeder for my pool and I wanted to get clear about something...
When I add a gallon of 6% bleach to my water, it will raise the FC by 2.1 and the salt by 3.4. Now this is something I could be doing sometimes on a daily basis. So my question is: though the FC essentially completely leaves the water, the salt remains to accumulate. Is this not a much slower version of the CYA situation? The salt will build up over time without draining ?
So if you can taste 2000 ppm of salt, you will notice this buildup after about 600 gallons of bleach? (minus whatever salt is in the water to start with?)
Seems like a 4-5 year cycle..??
Is this right?
Is this right?
