ping said:The quickest way to resolve the dust in the pool at this time is to gently use a manual vacuum. It wont take too long to vacuum and just be sure to vacuum the entire surface of the pool.
I believe you are seeing dust that just will not make it to the drains and just settles after each brushing. Use the manual vacuum then brush and most likely you will not see much dust at all.
Thanks a lot Ping,
I think you are right. The only thing is that I don't have a manual vacuum. Are there any you recommend out there that are affordable, yet effective? I even asked the pool store if there was some sort of net fine enough to pick up the dust, but no luck there.
